jetglo
17 Posts |
Posted - 09 Jul 2019 : 21:04:30
I am overhauling the fuel pump from my Series 4 which failed on the road. Following dismantling I found the underside of the diaphragm badly contaminated with oil due to failure of the pull rod oil seal. Although I have the repair kit, it doesn’t include the pull rod oil seal. I have tried all the usual searches without success: does any member know where one can be obtained? Also, the rocker arm pin is quite worn: any suggestions? Thanks Bob |
