Tone
36 Posts |
Posted - 05 Nov 2019 : 18:20:51
Hi all, my series V is running very rich, the plugs are sooty & black, does anyone know if the jets etc are available for the Solex B32 PAIAs carb? Or if a modern equivalent carb is available? If so which, numbers etc? Thanks in anticipation, Tone.
hillman
107 Posts |
Posted - 05 Nov 2019 : 19:19:50
| have you tried to remove your air filter and run without it? |
Posted - 05 Nov 2019 : 21:02:22
If you opt for another carburettor than without any doubt the so called Webcon conversion is the route to go. This conversion consists of a Weber 32/36 DGV 5A, a special manifold for this engines, a plenum, a K&N airfilter, petrol filter and connection between gaspedal and carburettor. But before going to do that that I should first investigate what causes the rich running and certainly a clogged air filter could be one of the possible causes of running rich.
