harley95
28 Posts |
Posted - 05 Aug 2019 : 09:08:45
I have petrol coming out of the manifold drain when the engine is turned off and it is running rich, i have changed the needle valve checked the float in hot water checked and rechecked the float setting changed all the jet's with new ones even the choke's and i have fitted a fuel pressure regulator set at 3 P.s.i.but there is still fuel passing into the manifold when i turn the engine off. Can anybody help ?
jbailey |
