 New fastback.
pollystag
Posted - 14 May 2019 :  10:10:45  Show Profile  Reply with Quote
Been a member a few weeks now,struggling to get my photos small enough, but this is the car on my trailer after 34yrs in a garage in crewe.
pollystag
Posted - 14 May 2019 :  19:56:56  Show Profile  Reply with Quote
Ok,anyone know why it's doing this?
I have posted one photo ok but this one is not showing for some reason.
ebdons
Posted - 14 May 2019 :  21:26:58  Show Profile  Reply with Quote
Hi, you might need an image resizer like (irfanview freeware) or list your images to jpeg.ton
pollystag
Posted - 14 May 2019 :  21:49:36  Show Profile  Reply with Quote
Cheers mate that's how I got the first photo on and I have resized a few more but when I put them on this is how it comes out.
Posted - 14 May 2019 :  22:00:49  Show Profile  Reply with Quote
Incredible that it is not possible to post pictures on this forum without that one has to try all kind of tricks in order to get the job done. That is the reason that I have stoppped trying to post pictures on this forum.
Fortuneately there exists other Rootes forum which accept a picture without the need of investing a lot of time to get it working.
The big question for me is: why this situation is like it is for many years?
Panky
Posted - 14 May 2019 :  22:25:45  Show Profile  Visit Panky's Homepage  Send Panky an AOL message  Reply with Quote
I use Imgur to host my pictures, it's free and dead easy to upload then link to a reply.
Edited by - Panky on 14 May 2019 22:27:38
Posted - 15 May 2019 :  09:19:19  Show Profile  Reply with Quote
Attaching a picture is not a problem, file size is usually what causes the issue.
If you make sure the file size is Max 500kb it should upload OK. File type is quite specific too, ensure you have jpeg images and then you will be good!
pollystag
Posted - 15 May 2019 :  13:01:44  Show Profile  Reply with Quote
I have reduced about half a dozen photos to below 200kb, the board is saying image accepted but it just comes out as above.
ebdons
Posted - 15 May 2019 :  18:31:09  Show Profile  Reply with Quote
Hi, sorry to hijack your post as I was trying to test my file size issue and maybe help you as well, some more pics of the outside, just starting to see what work is needed on the underside.
just testing and they load ok if using MS paint to resize to 500kb and ok up to that.Ton
Edited by - ebdons on 15 May 2019 18:31:41
pollystag
Posted - 15 May 2019 :  19:30:39  Show Profile  Reply with Quote
Think yours need to be about 250kb as it's a little large,ha
Aha, this on is 219 and has actually come out.
Posted - 15 May 2019 :  19:49:17  Show Profile  Reply with Quote
That boot floor doesn't look too bad. Have a look where the spare wheel cradle is attached, that is often a place that collects muck and rusts through. Also a good idea to remove the black trim panel at the back of the boot to expose the fuel tank. Then check the condition of the 2 rear strut mounts, another area that can rot through.
Look at my resto thread and you'll see what I mean
ebdons
Posted - 15 May 2019 :  21:25:03  Show Profile  Reply with Quote
Hi yes images a little large but that size is max on this forum under jpeg spec. yes will look at the rear structure soon but I know by tapping the rear valance it drops rusty metal on the garage floor so I reckon on a new rear valance and supporting structure, but I have budgeted for lots of panel and welding work. will see as the front looks okayish so far. Ton
pollystag
Posted - 15 May 2019 :  21:57:10  Show Profile  Reply with Quote
Looks like you are in for a welding marathon there,I hope you can get all the panels you need.
I was lucky with mine I got it started and serviced replaced all the braking system and then m.o.t'd it and it passed with just one advisory for a bit of welding about an inch square on an outrigger.
ebdons
Posted - 15 May 2019 :  22:49:04  Show Profile  Reply with Quote
Yep! I expected the welding, these rot like mad, but some of it is to do with the thin gauge body panels, no wonder they got so much out of a car with 1.7L motor? and my car has the original paint which looks to be 1 or 2 coats of topcoat at most, with a blue/grey primer. Linwood penny pinching? or normal factory procedure? onward to success! Ton
