 Crank Pulley Case
Posted - 07 May 2011 :  15:26:57  Show Profile  Reply with Quote
Hey guys
Im after a bit of help. As your probably aware my car loves to loose oil from around the crank pulley, even after fitting a new crank pulley.
After speeking to my mechanic, he has asked if a could source a new case (the one that reminds me of a kidney bowl) as he think mine is probably worn and to allowing oil of opening for the pulley.
If anyone has one they would like to sell me- im not worried if its not new, as long as its not at all worn.
ps if this doesnt work then ill follow previous advise and try some sealant
Posted - 07 May 2011 :  15:32:12  Show Profile  Reply with Quote
Ive just been told its actually called a timing chain cover
Posted - 07 May 2011 :  15:49:44  Show Profile  Reply with Quote
I'd be glad to help,
but I think there are people closer by who can help to mate!
That 'll keep things cheaper to! ;)
Posted - 07 May 2011 :  16:24:43  Show Profile  Reply with Quote
cheers buddy
Posted - 07 May 2011 :  17:22:38  Show Profile  Reply with Quote
Originally posted by UMU
cheers buddy
If you really can't find one... LET ME KNOW!!
Posted - 07 May 2011 :  17:51:29  Show Profile  Reply with Quote
Martin,
Is it not worth taking yours off, getting everything nice and clean then re-seal with a new gasket. You could use some hylomar to be sure.
I would imagine that would do the trick.
If not I probably have a spare but couldn't guarantee is would be any better than yours.
Cheers for now,
Jason.
Posted - 07 May 2011 :  18:45:29  Show Profile  Reply with Quote
I have read many comments over time about the tendancy of our Rootes engines to leak oil from the timing cover and the concencus seems to be that the design of the oil thrower and scrolled pulley shaft are never going to be totally efficient at retaining oil in the timing case.I recently saw a modified cover for sale on e-bay with a proper oil seal,but this was 'home made'.I have also seen various modifications on an Alpine website which reduce the amount of oil in the timing case and also suggest the fitting of a larger oil thrower.
ps just found website askthemechanic.co.uk
Edited by - johnc on 08 May 2011 11:37:49
jabe1807
Norway
Posted - 11 May 2011 :  22:09:20  Show Profile  Reply with Quote
Hi
Dodgealpine(dodgealpine@hotmail.co.uk) has made some timing chain covers with seal,that he is selling. Maybe he can help you.
Regards Jan
Edited by - jabe1807 on 11 May 2011 22:12:01
