 Replacement distributor springs
Posted - 21 Jun 2022 :  13:04:27  Show Profile  Reply with Quote
Lucas 23D4 distributor on a Holbay
I suspect my distributor's advance mechanism is faulty. The timing is all over the place.
When I manually turn the rotor it doesn't spring back.
Does anyone know where I might get a replacement set of springs?
Panky
Posted - 21 Jun 2022 :  13:50:11  Show Profile  Visit Panky's Homepage  Send Panky an AOL message  Reply with Quote
You could try the Distributer Doctor
http://www.distributordoctor.com/
It's more likely to be the spring that attached the top plate to the dizzy body that has failed.
Edited by - Panky on 21 Jun 2022 13:52:28
Posted - 22 Jun 2022 :  08:47:15  Show Profile  Reply with Quote
Hi Panky,
Thanks, I found the doctor via Google. He offered a full rebuild, which seemed a little over the top if I just need new springs.
But then again, the dizzy is 54 years old, maybe a complete rebuild is warranted.
I wondered what was usual practice.
Panky
Posted - 22 Jun 2022 :  14:29:31  Show Profile  Visit Panky's Homepage  Send Panky an AOL message  Reply with Quote
He's not cheap that's for sure but I thought he sold spares too. If it's just the return spring failed then you should be able to source one of an old Lucas dizzy I don't think that particular spring will be unique to the Holbay set up. It may of even just come un-hooked.
Edited by - Panky on 22 Jun 2022 14:30:33
