Topic |
Mr A.the Hun
65 Posts |
Posted - 06 Sep 2020 : 14:31:49
Hello, before I start giving myself a hernia, can I check that the Crankshaft Jaw (starting Handle) Nut, nestling in the Fan Belt Pulley is normal right hand thread, Nothing is mentioned in any of my Manuals regarding Left Hand Thread, but you would think L.H.T. would be more appropriate. Although one book (the Haynes Manual) suggests that rather than use an open ended spanner, (good luck with that) some examples would allow the use of a Tommy Bar through the starting Handle jaws, but this would then have to be Left Hand Thread.
Deep Socket is on its way, hopefully I can check which way to turn it before it arrives..
1725cc Alpine engine (in Series 3 Rapier), 1-5/16" deep hex with starting handle jaws (hooks).
Thank you. |
828CC
55 Posts |
Posted - 06 Sep 2020 : 16:46:44
There's a guy in Australia sells new ones (that's if the web search result is still current!) Might be worth an e-mail to him if all else fails.. https://www.sunbeamtalbot.info/aussiebob.htm |
205 Posts |
Posted - 06 Sep 2020 : 23:18:59
I found the only way I could undo mine on a series V Rapier was to use an impact wrench. The type used by tyre fitters on compressed air, or the new re-chargeable "pistol type" It took some real impact effort. A friend of mine used stiltons and a lump hammer! A bit crude but seemed to work. Yes, it's a conventional right hand thread.
jim |
Mr A.the Hun
65 Posts |
Posted - 07 Sep 2020 : 06:43:37
Thank you very much. Yes I have ordered a deep impact socket. I may still have to decide on a way of locking the crankshaft. Thanks again.
Mr A.the Hun
65 Posts |
Posted - 07 Sep 2020 : 06:46:45
And thank you for the website link. It’s also worth trying for some of the other items on there. |
828CC
55 Posts |
Posted - 07 Sep 2020 : 08:39:40
4th gear, handbrake on and chock the rear wheels.. Or remove the starter motor and wedge the starter ring gear..
320 Posts |
Posted - 07 Sep 2020 : 10:10:54
Or remove the metal shield between engine and gearbox and then wedge the ring gear (much easier than removing the starter motor).
Mr A.the Hun
65 Posts |
Posted - 07 Sep 2020 : 10:24:45
Thank you very much, and Geweldig, dank je well. |
205 Posts |
Posted - 07 Sep 2020 : 12:16:01
I was lucky in that I didn't lock the engine, using a good impact driver was enough. It just "shocks" the thread and unscrews it. Good luck anyway!
jim |
828CC
55 Posts |
Posted - 07 Sep 2020 : 13:40:16
TBH I'm not overly familiar with air tools, but I would be wary of using any 'impact' driver on something that has shims and bearings further up the line... |
Mr A.the Hun
65 Posts |
Posted - 07 Sep 2020 : 14:23:33
Thank you, I'm taking it all in. Once the big socket arrives, I will first try with my humungous breaker bar, and if that doesn't work I'll fire up the compressor and get the air tools out. |
Mr A.the Hun
65 Posts |
Posted - 11 Sep 2020 : 07:45:09
Thank you for everyones input. Once the 1 5/16" deep socket arrived, I attached my 800mm breaker bar, in 4th gear, wheels chocked, anti-clockwise force. Came undone quite easily. The positive power of the Forum. Excellent. |
Topic |
