 Chrome trim clips
plem1
Posted - 19 Nov 2017 :  19:39:57  Show Profile  Reply with Quote
Hi All
Does anyone know where I can buy the two types of clip for the chrome trim along the side of the rapier? I believe britos make them.
Posted - 22 Nov 2017 :  23:04:55  Show Profile  Reply with Quote
Hello, I take it that it is for a Series Rapier rather than the sill cover on the Fastback? Bresco do a number of clips and are pretty good, but I don't know if they do an exact replacement for s/steel strips on the Series car; someone on here might, or you could look at Bresco's catalogue on their web site. Cheers. G.
Posted - 30 Nov 2017 :  08:58:36  Show Profile  Reply with Quote
Further to above: I heard this from fellow member - may help?
"Assuming it's a series car Bresco do The thicker strip BSF 046. This is bolt through and needs a little filing to reduce size. The thin strip uses 17750."
RapierPhil
Posted - 30 Nov 2017 :  16:24:31  Show Profile  Reply with Quote
Hi there,
Are these the ones you are after?
Taken from Alpine West Midlands catalogue
Used them on my Rapier 1V restoration a couple of years ago
MF12 Side trim clips 15mm – metal - each All All 0.43
MF13 Side trim clips 9mm - each All All 0.25
Cheers Phil
72RPR
Australia
Posted - 01 Dec 2017 :  06:59:24  Show Profile  Reply with Quote
Hi, just purchased from Bresco some 'S' clips to hold the door trim on my Fastback. They were OK except that they needed to be thicker on the door than the ones I got. However, I have used them and the ones that were OK off the car, Fastback, so am happy overall.
