hillman
107 Posts |
Posted - 10 Sep 2017 : 18:23:23
hello friends, I will install anODon my serie 3a, thanks to bigt80 who provide mea gearbox and od. However i am now looking for : an overdrive switch (lucas part num 31992) a relay (lucas 33199) an inhibitorswitch (lucas 31849) if you have one of these and want to sell it please contact me. best rapier regards to all of you
gilles |
1053 Posts |
Posted - 10 Sep 2017 : 23:42:37
| Can probably help on the relay - leave it with me :-). G |
hillman
107 Posts |
Posted - 11 Sep 2017 : 07:53:03
Thanks Glen. I am thinking that a flasher switch, if I modify it, will do the job instead of a proper OD switch. Even a broken one. so....
best regards Gilles |
1053 Posts |
Posted - 13 Sep 2017 : 20:40:49
| Maybe; but what about starting with a Fastback one? I think the load that goes through the switch is quite high, so maybe an indicator one is not robust enough & it is better to use something suited more to the purpose? I don't know; it was just a thought. Cheers. G |
hillman
107 Posts |
Posted - 14 Sep 2017 : 08:26:40
Hi glen, May be , I don't know what a fastback one looks like. However, there is no load in the switch itself as it only sends low power to the relay which itself connect the power to the solenoid. The difference between aflasher and an overdrive switch is that the overdriveone does not stay in the commuted position but returns to the non connected position automatically. For example turn right position for overdrive and turn left position for the direct drive. but I will investigate the fastbacksolution. Thanks
Cheers Gilles |
paul marshall
136 Posts |
Posted - 21 Sep 2017 : 22:12:34
i have some switches and can get them to glen as i will be meeting him soon, i have relays as well let me know if you are still on the lookout rgds paul 07947632976, or i can post.
paul marshall |
hillman
107 Posts |
Posted - 22 Sep 2017 : 07:37:17
Hi Paul, Thank you for your message. Yes I am still looking for these parts. the 3 position OD switch and the relay going with it. tell me how much you want for this and we will see if Glen can take them as he is coming in France in October. thnak you andregards. Gilles |
