 Starter Motors (New/Old)
Posted - 10 May 2013 :  06:34:29  Show Profile  Reply with Quote
I had a lot of trouble with my old starter and slow cranking when hot.I overhauled the starter and checked all the normal stuff that goes wrong, but no luck - I just fitted a new starter exactly like the original and it starts first turn now, any time. Conclusion - the starters become cooked from the heat from the exhaust and years of service.
The new type starters are cool, but pricey.
Posted - 10 Mar 2013 :  14:20:56  Show Profile  Visit 1922's Homepage  Reply with Quote
All the Arrow/Hunter range switched over to pre-engaged starters in, I think, '74.
I've converted a couple of cars to these (a '68 and a '73), they bolt straight on. Just need to rearrange the wiring - just as Arrocuda wrote.
I never had any trouble with the ring gear.
Rootes 66
Posted - 10 Mar 2013 :  08:53:53  Show Profile  Reply with Quote
Isn't what you have there the "High Torque starter motor", It differs from the Pre-engaged by Power consumed and the speed it turns the engine over. I've not seen one but reports from the States where they are becoming increasingly common are all good.
What might be of interest, I seem to remember years ago seeing a Rootes Buletin warning that when changing from the old type starter to the then new Pre-engaged to change the starter ring on the flywheel, The lead in on the teeth, for smooth engagement of the dog is on the opposite side and if it wasn't changed could cause jamming of the starter.
Never had to do it so have open mind.
Pete
devnet H120
Posted - 09 Mar 2013 :  19:31:29  Show Profile  Reply with Quote
Hi Guys,
Got the new starter motor and I must say even though it is expensive I am a convert. This is a great bit of kit, turns the engine over with ease no horrible winey clunk and when your struggling to start your car it uses the battery 3x less than a standard.
I was always about using original nos parts but this little beauty has changed my mind!
Recommended.
devnet H120
grumpy1
Posted - 09 Mar 2013 :  16:19:01  Show Profile  Reply with Quote
Most new Lucas stuff is made there these days. Wouldn't trust the brand anymore myself. NOS is best!
Posted - 08 Mar 2013 :  09:10:16  Show Profile  Reply with Quote
A bit expensive! My local factors were still doing exchange items for a lot cheaper: they were Lucas, but could have been made in Mombogomboland! So not sure what quality they were.
Originally posted by devnet H120
Good stuff, I have ordered one of the below today, should fit straight on for the pre-engaged type.
http://www.amp-starters.co.uk/product.asp?strPageHistory=category&numSearchStartRecord=0&strParents=599%2C1582&CAT_ID=1582&P_ID=34394&btnProduct=View+More+Details
devnet H120
65beam
USA
Posted - 03 Mar 2013 :  04:21:00  Show Profile  Reply with Quote
the cars that came to the states had the pre engaged lucas starter with the solenoid mounted on the starter. i would say it was used on other cars of the time period.
Posted - 01 Mar 2013 :  08:01:20  Show Profile  Reply with Quote
The one I have came off of a Commer PB van and has the solenoid on the starter unit rather than the remote type of solenoid that in the case of the Rapier, is mounted on top of the inner wing. This is the normal arrangement for this type of starter. So you will need to extend the control wire from the ignition barrel so as it will reach to the starter, (mine was a couple of inches too short), and ideally you will also need to make up a continuous length of the heavy duty cable that provides the live feed from the battery (+ve) to the motor windings.
As a temporary measure you can get away with shorting it by moving the cable over on to the same lug as the cable from the battery on the existing solenoid that is mounted on the inner wing.
devnet H120
Posted - 28 Feb 2013 :  21:36:01  Show Profile  Reply with Quote
devnet H120
HunterGLS
Posted - 28 Feb 2013 :  20:59:22  Show Profile  Reply with Quote
And do you need to change anything else?
1972 Hillman Hunter GLS
1973 NSU Ro 80
1974 Fiat 130 Coupe
1973 Audi 100 GL
1979 Audi 100 Avant
1981 Audi 200 5T
1982 Audi 100 CS
Posted - 28 Feb 2013 :  20:44:49  Show Profile  Reply with Quote
What spec or make/model of pre-engaged starter can be fitted??
Posted - 28 Feb 2013 :  19:23:58  Show Profile  Reply with Quote
Me too.... cranks the engine over faster compared to the original 'ker-clunk' inertia type. Is a lot quieter too.
Posted - 28 Feb 2013 :  18:40:03  Show Profile  Visit 1922's Homepage  Reply with Quote
If you mean pre-engaged instead of the inertia type - then yes I have changed to the new style. It gets rid of the horrible whirr-clunk noise and seems to be more efficient.
devnet H120
Posted - 28 Feb 2013 :  14:20:33  Show Profile  Reply with Quote
Afternoon All,
Just looking for some views; I am thinking about buying one of the new style starter motors and fitting to my Fastback. I have a new reconditioned old style one but I am finding especially in this cold weather a struggle to get the car started and it drains the battery pretty quickly.
Has anyone got one fitted already...does it make a big difference?>
Thanks in advance.
devnet H120
