 Wiring
Posted - 24 Feb 2012 :  21:49:55  Show Profile  Reply with Quote
I only have one clear picture that might help you,
it's something to do with the starter, but don't think it's what you call the starter solenoid...
Could check on other cars for what goes were, but would take at least a week... (before I see them again)
Don't think it matters which wire goes where with the brake switch, it just has to make contact doesn't matter which way... (know what I mean)
Jon
Posted - 24 Feb 2012 :  20:53:04  Show Profile  Reply with Quote
You got any picks of where they fall in the engine bay and the conectors on the end?? Does the big brown one have a spade on it??
Ive put my rapier in my other garage over the old dears so cant refer to it but i labled all mine up
Hillman Avenger MK1 GT,
Commer PB Pick-Up x2,
Commer PB Panel Van,
Dodge spaceavan Auto sleeper,
Triumph Stag MK1,
Chevette HS x2,
Lancia Delta Integrale,
Fiat Mk1 Uno Turbo,
Here are some of my previous restos: http://www.turbocollective.net/phpBB3/viewtopic.php?f=49&t=1643&sid=e955c8d8a55dcf5aac9b7e2509ead07c
http://66.129.69.181/forum/topic.asp?TOPIC_ID=4594
http://66.129.69.181/forum/topic.asp?TOPIC_ID=4966&whichpage=1
Commer td conversion http://66.129.69.181/forum/topic.asp?TOPIC_ID=5275
Posted - 13 Feb 2012 :  22:35:03  Show Profile  Reply with Quote
Cheers Jon, here goes then;
Main (thick) loom
Group 1
2 x heavy brown cables & 1 x white with red stripe
All starter solenoid but not sure what goes where!
Group 2
2 x white with black stripes + 1 x white with green stripe
Ignition coil but again not sure on placement
Group 3
1 x green (sleeved) - Thermostat
1 x white with brown stripe - Oil temperature
2 x purple with black stripe - Horn
Then on a separate section of loom there is;
2 x green into single connector + 1 x green with purple stripe
These I think are brake switch, does it matter which way round?
And finally;
1 x green + 1 x green with brown stripe
Reverse light wires, attached to gearbox??
Jon
Posted - 08 Feb 2012 :  15:16:50  Show Profile  Reply with Quote
pop some pics up of the loom in place and i will guid you through
Triumph Stag MK1,
Chevette HS x2,
Fiat Mk1 Uno Turbo,
Posted - 07 Feb 2012 :  21:56:38  Show Profile  Reply with Quote
ome of the labelling I put on the wiring loom has not lasted too well and I could do with some help identifying what goes where.
I think I have sussed most of it from the position but confirmation would be good.
So if anyone can have a look around their engine bay and give me some clue as to the wire colours going to various components it would be most appreciated!
I should point out that I do have the workshop manual wiring diagrams but they are not the easiest to follow!
Thanks.
Edited by - JPSH120 on 08 Feb 2012 07:55:41
