 series door handle gasket
hillman
Posted - 07 Nov 2019 :  08:02:56  Show Profile  Reply with Quote
Thank you Peter for this very important information.
gilles
Posted - 05 Nov 2019 :  14:15:06  Show Profile  Reply with Quote
And indeed although the part number for the handles are different the part numbers for the gaskets are the same. So the gasket ment for an Alpine door handle will fit the door handles from a Rapier.
hillman
Posted - 03 Nov 2019 :  15:07:22  Show Profile  Reply with Quote
Hi tgr747,
thank you for the info. they look very similar I will order a set from them as they will probably do the job.
Thank you
Posted - 03 Nov 2019 :  13:32:59  Show Profile  Reply with Quote
The handles for the Alpines have different part numbers compared to the handles of the Rapier, so I assume this handles are different!
tgr747
Posted - 03 Nov 2019 :  11:03:47  Show Profile  Reply with Quote
If the handles are the same as a sunbeam alpine,firms like sunbeam spares co stock them.
hillman
Posted - 01 Nov 2019 :  09:50:20  Show Profile  Reply with Quote
Thank you Jim,
I will do this if I cant find any new gaskets.
cheers
Posted - 01 Nov 2019 :  08:14:52  Show Profile  Reply with Quote
I usually use a scrap of old cycle inner tube. fix the handle on top of the rubber trimmed from an inner tube, then VERY carefully trim around the handle with a sharp knife, stretching the rubber slightly so the cut edge hides under the handle.
jim
hillman
Posted - 31 Oct 2019 :  18:09:41  Show Profile  Reply with Quote
Hello, I am looking for door handle gaskets for my rapier 3a.
Any idea where I could get a pair? thank you
