Posted - 25 Aug 2017 : 09:41:54
With a completely new engine the compression pressure should be 175/185 lbs which translates in 12.3 to 13 kg/square cm. The difference between the highest pressure and the lowest should be no more than about 10%. In your case the difference between cylinder 2 and 3 is 20 lbs which calculates for about 15% when we take 140 lbs as a basis to calculate from. If you experience no specific problem I should do nothing with it. If you are interested to know what could be the cause of your observations than the following procedure gives you more information:
Run the engine to operating temperature; Take out all spark plugs; Put a tea spoon of oil in a spark plug hole and measure again; Proceed with a tea spoon of oil until you have measured all 4 cylinders.
When the compression pressure is higher than the measurement without the tea spoon of oil then the problem can be related to pistons and/or piston rings. If the compression pressure remains the same then most problably the valves are the culprit.
