puffin
21 Posts |
Posted - 22 Apr 2013 : 21:58:36
Hi everyone, My name's David and I live near Liskeard in Cornwall. I joined SROC a little over a year ago as I felt membership of the Club would be essential if I was to find an H120, which I had decided would be my second classic. My first, a Vauxhall Sports Hatch (1976) I had for 18 years until it caught fire and was a total loss. I'd always admired the fastback Rapiers as stylish cars, so I took the insurance money and started looking... Eventually in Jan. 2012 I went to Ashford in Kent to see Jim Mortons car, CTG 766J which was immaculate- the only problems I had befor MoT-ing her was a frozen clutch, siezed brake calipers, both master cylinders and a starter motor. The body and interior were astonishingly good- beautifully undersealed and great for age. My 14 yr old daughter Tabitha wanted to call her Polly (after Apollo), but secretly I've named her Phoebe... I hope people will be in touch- I'm a great believer in keeping old things going- me for a start! When I've worked out how to attach some pics I'll do so, but it's got me beat so far... All the best for now, David
1053 Posts |
Posted - 22 Apr 2013 : 22:11:21
Welcome to the forum David and glad too, to hear you're a club member. Car sounds great and sounds like it was a great find. Perhaps we might see you at the National in August? Look forward to seeing some pics. soon. Cheers.. G. |
1198 Posts |
Posted - 23 Apr 2013 : 08:11:51
Welcome to the forum David and nice to hear from another H120 owner, you'll have to keep her well protected from the cornish sea air down there!!
Attaching photo's can be done 2 ways. Either create a photobucket account and upload photo's to it, then you copy the IMG codes from photobucket and paste them into the post.
Alternatively (and probably easier) if you look at the bottom of the window when you are posting you'll see a paper clip & "Insert an Image File" - click on that and follow the prompts.
puffin
21 Posts |
Posted - 24 Apr 2013 : 23:48:14
Well, the last one was a disaster, so I'll try again...
Edited by - puffin on 28 Apr 2013 21:47:41 |
1198 Posts |
Posted - 26 Apr 2013 : 08:13:26
Something doesn't seem to be working quite right, I tried to upload a picture directly to the website and failed. Looks like photobucket is your best bet for now...
Administrator
111 Posts |
Posted - 26 Apr 2013 : 18:05:44
Odd, can you send me the images you are trying to upload and I'll have a look - might the size e.g. dimensions or MB
1053 Posts |
Posted - 26 Apr 2013 : 20:40:33
That's fine looking Rapier, even in poor res. Wonder what happened to that  |
puffin
21 Posts |
Posted - 28 Apr 2013 : 20:54:21
Hi Glen, Didn't I send you pics of the car? If I did, can you upload- if I didn't, can I e-mail them to you?? ATB David |
Edited by - puffin on 28 Apr 2013 20:59:29 |
puffin
21 Posts |
Posted - 28 Apr 2013 : 21:49:14
I've worked out how to do it via Photoshop- now completely ***ckered, so going to have a drink... ATB David |
1198 Posts |
Posted - 28 Apr 2013 : 22:18:47
Very nice and the colour looks good too. I hope to meet you over the next few months, are you planning to attend any of Malcolms events?
puffin
21 Posts |
Posted - 29 Apr 2013 : 21:58:19
Hi there, Yes, I'm very pleased with her- hope to get to Malcolm's events, as he's just sent me the list for 2013. However, I do have a little bit of a problem with hot starting and a 2000rpm misfire. I'm as sure as I can be that it's not ignition- I've just fitted luminition, red rotor arm and new plugs/HT leads and dizzy cap, so I think it's a fuel supply problem. I've stripped both carbs and checked jets etc, new needle valve/floats etc, and I noticed when she was good and hot that there were lots of bubbles coming up from the fuel pump. I'd already fitted a new diaphragm and the presure was 3.5-4 psi which is spot on, so I think what I have is a partial vacuum developing in the fuel tank, and /or an air leak into the fuel pipe somewhere between the tank and the pump. This would explain the symptoms which are effectively partial fuel starvation, made worse by high underbonnet temps causing some vapour lock. SO...I'm going to clear the filler cap vent or make another one, replace the old fuel pipe with 8mm Kunifer, fit a 10 psi electric fuel pump and a Filter King filter right by the carbs (to drop the pressure back down). I came up with this solution after reading all the all the tech forum stuff and chewing it over with Rob at Eurocarb. Have you ever had any problems like this? People seem to be saying it's down to unleaded fuel, but I'm adding Tetraboost to mine (TetraEthylLead), which should make it identical to the old 4 star... I don't know, it's all a bit of a puzzle wrapped in an enigma etc... ATB for now, David |
Jon
221 Posts |
Posted - 29 Apr 2013 : 23:13:17
Its to do with the inside of your tank coming away and ending up in the fuel line/pump from my experiance. Rootes group painted all the insides of the tank! If you have the glass bowel fuel pump take the bowl off and have a look inside the pump. Worked great with the old four star fuel but not the new unleaded with more methanol than ever! It works like paint stripper I had a load of trouble with my rapier,my commer van,my avenger and my friend who also has lots of rootes vehicles also having the same problem. Ive now fitted a custom made ally fuel tank to my commer its now sorted Another way is remove your tank,chuck a hand full of nuts and bolts in,strap it to a cement mixer and leave it goin for a few hours! Soon strips it all off to nice shiney metal
Hillman Avenger MK1 GT, Commer PB Pick-Up, Commer PB Panel Van, Commer Auto sleeper, Triumph Stag MK1, Chevette HS x2, Lancia Delta Integrale, Fiat Mk1 Uno Turbo, Rapier Fastback, MGZS 180kit TD MK2, MK5 Transit Hallmark 1965-95 celebration, MK5 Transit 2.5td 150,
Posted - 01 May 2013 : 07:54:45
puffin
21 Posts |
Posted - 02 May 2013 : 21:54:22
Well, it seems clear I need a good look inside the tank,so I might as well take it out while I'm doing everything else- it looks like a straightforward job (famous last words). ATB David |
1053 Posts |
Posted - 04 May 2013 : 19:35:12
Yes, a general problem for older motors now that the meth. content is higher; some gasket sealants that were impervious to petrol; are no longer. Also if breather not working properly it can allow build up of condensation when car laid up for long time & result in same problem. Once that inner coating starts to flake off there isn't much you can do. Not sure if the cement mixer and nuts will work as with all the baffles inside I don't know if it would get to work on the whole of the inside. Not sure either if slosh sealant is still around and if it is how effective it is. All in all a right pain  |
423 Posts |
Posted - 05 May 2013 : 09:19:13
It will work Glen, don't know about the cementmixer, but cleaning it with nuts and blots etc. inside really helps. We did it with a set of a sunbeam alpine (no baffles) tanks and we could really see the flakes coming out when we emptied it... we did use little stones... We also partially did my tank while we were at it and although the baffles might be in the way it works, you might have to hold it in a certain position to get the stones past the next baffle but it will work. Afterwords we got an epoxy sealer that was specially made for these applicatons and coated the inside of the tanks car still drives great without any problem! Hope you get it fixed David! Good luck, Thomas
