 Exhaust manifold studs
Posted - 13 Oct 2012 :  17:42:46  Show Profile  Reply with Quote
Hi all,
I'm having difficulty getting a seal at the manifold/downpipe joint as the stud threads are badly worn and I can only tighten the nuts by using several washers.I want to renew the studs but in the event of them breaking off (most likely),I am considering drilling out the remains straight through the stud holes and fitting s.s.bolts/nuts.
My question is has anyone sucessfully drilled through a manifold in this way,it is a SIV with 'blind'holes and fitted bolts instead of studs.
With manifold off it's now clear that the bolt option will not work,it would on a later SV manifold,so I'll have a try with new longer brass nuts before I resort to drilling out the studs etc etc.
Edited by - johnc on 15 Oct 2012 14:10:08
Posted - 15 Oct 2012 :  18:46:54  Show Profile  Reply with Quote
Could you not re-cut the thread to improve the "bite"??
Posted - 16 Oct 2012 :  14:34:24  Show Profile  Reply with Quote
I've run a good nut down the studs,with plenty of oil,and it seems to have improved the situation so hopefully the longer brass nuts will sort the problem.
