 Engine colour
jabe1807
Norway
Posted - 26 Oct 2011 :  18:55:03  Show Profile  Reply with Quote
Hi
I am going to paint my Fastback engine, which now beginn to be a Holbay engine. Does anyone know if it is the same blue colour on Holbay and standard engine?
Regards Jan
Posted - 26 Oct 2011 :  20:04:22  Show Profile  Reply with Quote
Jan,
Yes the block would be the same colour. I bought my paint from frost restoration and it is listed as chrysler blue although I think the original colour was darker.
jabe1807
Norway
Posted - 26 Oct 2011 :  21:30:09  Show Profile  Reply with Quote
Hi
I have seen the picture of your engine(if I am not wrong) and it looked lighter than my own engine. I will mix a color that will be as like as possible my standard engine, and it is quite dark blue.
I put in some pictures soon. Thanks
Jan
Edited by - jabe1807 on 26 Oct 2011 21:31:23
Posted - 27 Oct 2011 :  12:52:39  Show Profile  Reply with Quote
Hi Jan,
Yes my block is lighter then what I think was the original colour, although I have seen some with even lighter blue. I actually don't mind as I think it will be better with my dark green body colour.
I think the darker one you want is more like this;
Frost do have other blues that are darker, might be worth you speaking to them.
jabe1807
Norway
Posted - 27 Oct 2011 :  16:44:17  Show Profile  Reply with Quote
Hi
I have bought paint today, as like as the old color on my engine. I put in some pictures of it when that job is done. (hope for a good result).
Here are 2 pictures from my engine work. I have fixed up my garage to work on my Fastback( I dont tell my wife that was the reason!.)
Do I have to put in new nuts on the connecting rod? I can turn them by my fingers, but it dont seemd to be locknuts.
Posted - 29 Oct 2011 :  10:40:42  Show Profile  Visit 1922's Homepage  Reply with Quote
Hi Jan,
In the past I have used the nuts two or three times. I had no problems.
But when I built my Holbay I used new factory nuts, just to be safe.
The workshop manual says "Fit new nuts". If you buy new nuts you need 11/32 inch, 24 threads-per-inch, UNF.
jabe1807
Norway
Posted - 29 Oct 2011 :  17:15:28  Show Profile  Reply with Quote
Hi
Ok, thanks. I will try to get som new nuts here i Norway. It is best to be safe.
Paul
Posted - 30 Oct 2011 :  00:58:18  Show Profile  Reply with Quote
There is a specific warning in the WSM to make certain you don't use 3/8" 24tpi by mistake which are used in some other Rootes engines and which will fit quite happily. The right nuts are usually Nyloc and what the WSM says is that you can re-use them if you can't screw them on with your fingers. To be honest, I've also always re-used them, even on my rally Alpine and I would rather do that than use a new nut of an unknown grade. If you can screw them on easily by finger tip and they don't appear to be lock-nuts, then I would suspect that someone has changed them for the wrong type sometime in the past and I would try to get hold of some genuine originals.
I'll try to post a photo of the right ones tomorrow later today!
My Alpine won't float! I need one which does!!
Edited by - Paul on 30 Oct 2011 00:59:37
Posted - 30 Oct 2011 :  10:31:04  Show Profile  Visit 1922's Homepage  Reply with Quote
The nuts I've seen are twelve sided, you can use a standard bi-hex socket on them or a ring spanner.
Not seen Nyloc ones.
My Chrysler 'Hunter Range' manual has the warning about 3/8 UNF but it just says "Fit new nuts" - nothing about being able to re-use them. I guess this is a change from the earlier times, more worried about the warranty claims than saving a quid on new nuts .
But like Paul - I've reused the nuts many times.
You can probably get a set from Speedy Spares or http://www.rootesparts.com/.
I doubt it will cost much postage just for 8 nuts!
Edited by - 1922 on 30 Oct 2011 10:31:35
jabe1807
Norway
Posted - 01 Nov 2011 :  15:45:42  Show Profile  Reply with Quote
Thanks for the feedback. I will contact speedy spares to get new nuts. Regards Jan
jabe1807
Norway
Posted - 01 Nov 2011 :  15:46:52  Show Profile  Reply with Quote
Originally posted by jabe1807
Thanks for the feedback. I will contact Rootes parts to get new nuts. Regards Jan
