 Retrocars Mag
Next Page
Page: of 2
Posted - 04 Apr 2011 :  17:40:25  Show Profile  Reply with Quote
Hi guys
I have just got back from a long weekend away in Kent after going to my friends wedding and managing to coinside it with a photoshoot with Retrocars mag.
All i can say is WOW the cammera they use and the ability of the cameraman makes the car look really really good.
Anyway expect to see it in the magazine in 2 months time - should be a good one
ps the car covered over 700 miles this weekend, most of it at 75mph (thats measured by a satnav as speedo doesnt really work) and the car hasnt faulted - really impressed, however i have used about 1.5l of oil, is that normal??
cheers
Posted - 05 Apr 2011 :  16:19:50  Show Profile  Reply with Quote
Hi Mate,
Looking forward to seeing the Retrocars mag!
Let me know what issue it will be in...
The 1.5l oil you used, isn't that normal,
but it can happen..
When you're driving 75 MPH for a longer time, the oil gets hotter and thinner then normal.
So it could happen that when you have a small leak when driving around town, this leak gets bigger, because of the thinner oil...
We had it on our Triumph saloon MKI 2.5PI and it was just the oil ring in the timing cover.
So a small leak can leak harder when driving faster for a longer time because the oil gets thinner.
Posted - 07 Apr 2011 :  18:49:24  Show Profile  Visit 1922's Homepage  Reply with Quote
That's also the normal place for a Rapier to leak.
Have look at the timing cover behind the crank pulley if it's leaking there you will see that the bottom of the timing cover, the front of the sump and the crossmember are oily.
If the timing cover wasn't centralised properly around the crank pulley then the pulley will wear the cover and this gets you an oil leak. You cannot replace the oil seal because there isn't one!
I used to have to top up the oil every week (250 miles), after I fixed that leak it was every three months (3000 miles).
I cured the leak on mine by coating the crank pulley boss with silicone gasket then refitting it. As long as the timing cover is oily the silicone will not stick to the timing cover but will stick to that crank pulley (as long as you degrease it first).
Leave it for a few days then you will have leak proof crank pulley.
I know it doesn't sound like it would work - but mine has done thousands of miles. Saved me a small fortune in oil. I was worried that the silicone would break up and clog up the oil ways - but when I removed the timing cover (after several years) to check it was fine.
Edited by - 1922 on 07 Apr 2011 18:50:10
Posted - 07 Apr 2011 :  19:38:24  Show Profile  Reply with Quote
Forgot,
just generally check the engine for leaks.
Could come from a lot of places, actually...
The timing cover is just one possibility...
There's also
- the side cover
- where the distributor is fitted to the engine. (perhaps it leaks not that hard)
- between the engine and the oil-filter housing (there's presure on the oil that passes true there)
- the rocker cover
- the sump
our humber sceptre was, everytime, even after a short distance, leaking very hard...
Changed the rocker cover gasket, the side cover( and at the same time the distributor gasket and the oil-filter housing)
Solved the leaking!!!!
Posted - 08 Apr 2011 :  00:28:11  Show Profile  Reply with Quote
Thankyou thats really kind of you both.
I will check the oiliness of those areas and take some pics too.
Im well chuffed u have a solution for this, although my local mill autos wont be so happy if i stop buying so much oil!!
thanks again
Posted - 08 Apr 2011 :  17:47:28  Show Profile  Reply with Quote
I'm glad whenever I can help mate!
Posted - 10 May 2011 :  17:56:19  Show Profile  Reply with Quote
Hey guys
I have next to me a copy of this months (June) Retrocars mag and im well chuffed. UMU has been featured and looks her best - Even the centre spread (once turned around) is of the Beam!!
It should be on sale in the next 2 or 3 days.
Happy reading
Posted - 10 May 2011 :  18:11:31  Show Profile  Reply with Quote
I'll sure buy it!
I wouldn't want to miss it!!!
Posted - 23 May 2011 :  17:17:01  Show Profile  Reply with Quote
Hey mate,
Read the article last Friday!
Stunning car! Didn't know you had dvd in the car! ;)
Might be an addition for when mine is finished! ;p
It really looks nice!
Posted - 23 May 2011 :  19:09:52  Show Profile  Visit 1922's Homepage  Reply with Quote
I'm still trying to find a copy, no one near here seem to stock it.
Posted - 23 May 2011 :  20:28:03  Show Profile  Reply with Quote
I get my copy from Asda. If you get stuck;
http://cgi.ebay.co.uk/Retro-Cars-Magazine-June-2011-Rapier-Alfa-Sunbeam-/280683393323?pt=UK_Magazines&hash=item415a08b12b
Posted - 23 May 2011 :  21:33:48  Show Profile  Reply with Quote
Hey guys
Only selected shops sell it, which can really prove annoying.
But the likely ones are WHSmiths, Morrisons, Martins newsagents, larger Asda, motorway services(usually)
You have until June 10th to get one, before next months is released, so still have plenty of time.
Yeah Tom, the latest addition was the DVD unit after my cd player stoped working. its blimmin ace and also looks bril when its turned off as its so simple and subtle.
Posted - 23 May 2011 :  21:35:07  Show Profile  Reply with Quote
By the way well done for finding that one on ebay Jason, good one
Posted - 24 May 2011 :  15:44:45  Show Profile  Reply with Quote
What type is it, can you give me some info about it so I might be able to find something similar.
I like that it would be subtle like you say...
Thanks mate!
Posted - 24 May 2011 :  19:28:00  Show Profile  Reply with Quote
Haha ive just found this on youtube which has a very enthuastic guy who goes through everything about it.
http://www.youtube.com/watch?v=zr5yuzQwbeE
see what you think, cheers
Posted - 24 May 2011 :  20:26:21  Show Profile  Reply with Quote
Wow mate, I'm speech less!
couldn't be any cooler!!!
Thought expensive...
I'll be sure to find something like it!
Thanks for the info mate!
Edited by - Fastback Thomas on 24 May 2011 20:36:41
Page: of 2 Previous Topic Topic Next Topic
Next Page
