                  Topic   |
                343 Posts  |
                       Posted - 12 Jan 2011 :  21:49:45
                       So back in the summer I met Glen and managed to buy a pair of strombergs off him.  Good thing as the ones on my car are on their last legs and need replacing. Now that i have bought the resto kits and have a little bit of time ive decided to sort them out, ready for fitting.
  So far i have desmantled them and now started cleaning. Any tips??
   I have a very understanding fiancee
   Left = cleaned and right = as it was
  I have a long way still to go, ill keep u posted
                549 Posts  |
                       Posted - 13 Jan 2011 :  13:23:26
                       Long while since I touched one of those. There are fairly straightforward and reliable - as long as you don't drop any of those tiny bits and lose them in the carpet
  Those are the earlier CDS type with the adjustable jets - which is good because they don't have the spring biased needle of the later CD3 carbs (those wear away the main jet very slowly). I have a couple of copies of the Haynes 'Zenith Stromberg CD Carburettors Owners Workshop Manual', I can bung a copy in the post if you want one. No use to me, both my cars have webers. If you haven't already got one, get a copy of the Chrysler WSM149 Hunter Range Workshop Manual - it has an excellent section on rebuilding those carbs (much better than Haynes!).
                       Edited by - 1922 on 13 Jan 2011  13:28:06 |
                423 Posts  |
                       Posted - 13 Jan 2011 :  17:45:05
                       hi bud, you should clean the pistons, that go up and down with the needle, with chrome polish, takes all the little inperfections away. Clean them until they slide real easy in and out there housing.
  I like a car that looks normal but can really knock you off your socks! |
                343 Posts  |
                       Posted - 13 Jan 2011 :  18:11:42
                       Hey guys thank you so much for the advise
  Im having a go without any real knowledge, so much appreciated.
  Derek i think i actually have that manual - i will dig mine out and make sure.  thank you for offering to send me yours though.
  Do you think the fact my engine is now a 1.9cc it will ever run properly on the standard stombergs??? If theres any modifications i should make to mine, please let me know.
  I did think about putting webbers on mine, but was advised that it would run smother with strom's and thats before i found out how much they cost (WOW) so ive decided to make the best out of what i have
                1194 Posts  |
                       Posted - 13 Jan 2011 :  18:23:56
                       Good luck with that mate, you're a braver man than me pulling those to pieces!
  I would imagine you'll have to increase the fuel supply through the carbs to satisfy the extra cc's.
  Webers aren't cheap but they do sound good
                343 Posts  |
                       Posted - 13 Jan 2011 :  21:10:08
                       Cheers buddy, looks like theres lots of parts doesnt there - but so far all seems to be straight forward, but hey ive only taken things apart so far.
                85 Posts  |
                       Posted - 13 Jan 2011 :  22:24:15
                       Good job, looks fun. Don't forget to polish the brass tags if you still have them. One of my fave bits to do with brasso.
  Good to see you have an original t- piece but inspect it carefully for cracks. The White pattern ones are rubbish and can split after just a few miles causing potential disaster. The other thing is when cutting the thread on the plastic pipe into the t-piece, be very careful a sliver of plastic doesn't come off. It can wedge open the float valve and lead to the float chamber spilling out it's overflow onto the exhaust. Later cd3 are better here as I think there is a gauze to prevent this. |
                549 Posts  |
                       Posted - 13 Jan 2011 :  23:03:38
                       My 1840 runs wonderfully smooth on webers - it will tick over at 600rpm and manage 30mpg, better than I ever got from strombergs.
  Those CDS carbs have adjustable jets so I'm sure you can get it to run ok - but keep an eye on ebay for some H120 carbs (or you could ring Big Kev if you are feeling rich!).
  I'm very curious how you got 1.9 litres - that's quite a jump from 1725, more than 2mm overbore, what sort of pistons were used?. Did they use liners? What about the cam?
                       Edited by - 1922 on 13 Jan 2011  23:06:59 |
                549 Posts  |
                       Posted - 13 Jan 2011 :  23:10:52
                       Paint thinners is good for cleaning the brown petrol 'varnish' from inside the carb - but it's rather smelly and not good for the carpet so it's not popular indoors
                       Edited by - 1922 on 13 Jan 2011  23:11:08 |
                 mikesunbeamH120
                35 Posts  |
                       Posted - 14 Jan 2011 :  12:37:11
                       Hi all, just to let you know . howard jonhson has an H120 and he had it rebored to 1.9 he used volvo pistons hope this helps ...
   Good luck with the rebuild of your carbs Martin, like fastback thomas said chrome polish is good. Also try carburretor cleaner that usualy works all the best mike.. |
                343 Posts  |
                       Posted - 19 Jan 2011 :  20:32:08
                       Hey guys Sorry ive left it for a while, but thanks Mike your spot on and i was going to use Volvo pistons, but decided to use a set from Australia - apparently they use them in there 'Utes'
  But im not sure how much they had to bore out and if they had to use any special techniques etc.
  Although i havent got much further with the carbs etc i have some photos of what i have done. Also have managed to fit the centre to my new steering wheel - so now it looks the part i think
  ps the engine in my company van died today - the big end failed - luckly its not my responsibility to fix it, but still was a shock
  cheers
                549 Posts  |
                       Posted - 20 Jan 2011 :  13:54:23
                       Very shiny - you reliaze you'll have to keep polishing them now
  Yup - Howard Johnson's motor is 1860cc using Volvo P1800 pistons, my 1840 Rapier uses shortened MGC pistons, and my new 1922cc uses 1600 Avenger pistons. I was just curious.
                501 Posts  |
                       Posted - 20 Jan 2011 :  18:51:46
                       I think we need a thread in the tech section about these different piston arrangements.  I'd heard of using other Rootes/Chrysler models but never knew you could make P1800's fit.  Now what I wanna know is.... Does anyone have any compression ratios for any of these conversions?
  Also Derek... I noticed you posted to your 'Minx mayhem' thread but  when I went there....  was no post!  Very strange!
  I'll start a new thread in tech' cos I don't want to hijack Martin's strommy thread.
                343 Posts  |
                       Posted - 07 Mar 2011 :  18:32:11
                       Any chance you can advise where to go from here
  As im so so so lazy and not getting on with the stromberg resto i have been thinking of ways to avoid it
  The route im hoping to go down asap is converting to webers, only im not sure which ones will suit my engine Could anyone advise (bare in mind i have the standard rapier engine, bored out to 1.9cc)
  The most common ones i see used seem to be 40s and 45s, but that doesnt mean much to me Im in a bit of a hurry now as Retrocars mag have now set a date to feature my car and im having the photoshoot on 2nd April
  aaaaaahhhhhhh   cheers
                423 Posts  |
                       Posted - 07 Mar 2011 :  18:59:24
                       Hi mate,
  Don't know the specifications of the 40's or 45's but I think it might be short notice to convert to webers. If you can find them fast, you still need to get them on, running and driving properly. Might be difficult in less then a month.
  I recon you could have the carbs cleaned and put back together (if you have everything you need) in an afternoon... and they're probably easier to tune then the webers.
  But that's only my vision mate.
  I like a car that looks normal but really knocks your socks off!! |
                549 Posts  |
                       Posted - 07 Mar 2011 :  19:08:15
                       The DCOE 40s fitted to H120 have 30mm chokes - i.e. the hole through the middle is only 30mm so I wouldn't bother with the 45s it would be overkill and you are on your own with the jet selection. My 1840 Holbay marathon engine uses the standard H120 set-up and it runs great so I'd say that the best bet is to get some second hand H120 or GLS carbs on the manifold, clean them up and bung them on. Buying new is VERY expensive - something like 300 quid each carb once you've paid for the jets (and you will also need an inlet manifold). Your 1.9 will probably run fine on H120/GLS carbs.
                  Topic   |
