205 Posts |
Posted - 16 Jan 2020 : 15:14:14
I've fitted two to my series V. The only thing I would strongly suggest is to have supports professionally soldered to the header tanks to fix the fans to. The cheap/easy way is to use the long bolts straight through the core fins, these can sometimes rub holes in the tubes. I had mine mounted on the forward side of the radiator so you can still have the original fan in use as well if you so wished.
jim |
