 Alpine discs on series one rapier.
filister
USA
Posted - 22 Dec 2018 :  06:22:44  Show Profile  Reply with Quote
Hi guys, trying to update my Rapier to Alpine discs. I have a complete alpine crossmember. Just using the spindles limits the turn radius. Not sure why. All parts seem the same. Anyone do this? How? Thanks for any help. Jim, USA
filister
USA
Posted - 23 Mar 2019 :  04:10:05  Show Profile  Reply with Quote
So, I have now finished this conversion and it is working well. I used Alpine series 4 spindle with series 5 hubs, rotors, steering arms and calipers. Also used the thicker anti roll bar. Some notes on the conversion:
Extends the front track by approx. 1" per side.
Had to use alpine tie rod ends inner and rapier tie rod ends outer. The rod pins are different sizes but the rod threads are the same.
Used 1974 capri calipers (much cheaper) which are identical to alpine except require a metric to british thread adapter.
Also added 1725 engine, all synchro tranny and 3:89 rear end. Very happy with conversion.
hillman
Posted - 02 Apr 2019 :  17:07:20  Show Profile  Reply with Quote
Hello,
did you install vent discs on it?
can wr talk about this in mp?
thank you
gilles
filister
USA
Posted - 20 Apr 2019 :  21:51:43  Show Profile  Reply with Quote
Hi, just used standard Series 5 rotors. 1/2" solid. Not sure what mp is but I'd be happy to discuss.
hillman
Posted - 23 Apr 2019 :  17:33:33  Show Profile  Reply with Quote
Hello thank you for the info.
I plan to install an alpine serie 5 front end on my serie 3a rapier and will go for a 1725 later.
I will think about the capri calipers this is a good idea.
thank you
mp means private mail
