1191 Posts |
Posted - 15 Mar 2015 : 14:21:57
Hi guys, need some help!
I've had to remove the nsf strut as it was not functioning correctly. My plan was to replace the innards with those from the old strut (I replaced it during my resto) but they are different.
The newer one has a Monroe insert which appears to be a sealed unit and I'm assuming has run dry of oil. The older one has a different type of insert which I'm assuming is original which I could re-use. It has oil in it but the insert comes apart and I'm not sure what oil levels should be etc.
So, need to find a replacement Monroe strut or get some advice on how the older insert works if anyone knows. I'll post up pictures if necessary.
Thanks.
JonandJude
84 Posts |
Posted - 15 Mar 2015 : 16:10:07
Hi, I have a pair of original inserts sitting in the workshop after changing them for spax units. Doesn't look much wrong with them and only changed them as I was doing the top bearings and thought I may as well dave coming back to them later, you can have them for the postage if they're any use to you? Jon
1972 Rapier H120
1191 Posts |
Posted - 15 Mar 2015 : 18:02:53
Thanks Jon,I might take you up on that if I don't have another solution. I'll let you know.
Jason.
1191 Posts |
Posted - 20 Mar 2015 : 06:50:34
I've bought a pair of replacement inserts from speedy spares, thought I might as well put new ones in.
Thanks for the offer John.
JonandJude
84 Posts |
Posted - 20 Mar 2015 : 07:47:00
No worries they're just lying in the corner. If they're any use to anyone else please feel free to ask.
1972 Rapier H120
onefunkyman
60 Posts |
Posted - 26 Mar 2015 : 07:57:28
I fitted Spax shocks to mine, they are adjustable and a swine to fit, but at least you can still buy a complete set of fronts and rears and simply "bolt them in"
in their soggyest position they feel like the originals and not too sporty, beyond setting number 1 they get a bit bone shattering!
regards, Dave |
